DR350 help QUICK !
Ok, We are selling my dads 1998 DR350se.
Only a couple things are wrong with it.
1)It Bogs at first when it is cold, After a minute, it doesnt do it.
It never did that before
2)The neutral light doesnt go on, Before whenever it didnt, I could just rev it and it would go on.
How can I fix these ?
I need to know quick !
Also, Is 2500 a good price for it to sell for ?
When cold the fuel enrichment valve (choke) does what it sounds like. Try richen up the pilot screw for potential solution.
Yea sounds like choke.
Check the wires to neutral LED Try to wiggle it. check all connectors. Make sure it has good ground.
Ok, Which way on the petcock is on ?
(I know I sound retarded but It has like Pri. ? and some other stuff)
Petcock is always on. If you can see the PRI or Prime position then the ON is next and the REV is 180 the other way from PRI. It's vacuum operated so it's always on when the engine is running and off when it's not unless it's on PRI in which case it's on regardless.
If it's doing this and never did before then I wonder if it was stored for a while and the carb's idle circuits are a little gummed up. Otherwise you may be just trying to come off the choke too quick. Full for starting and then there should be a 1/2 way out for warming up for a few minutes.
