Throttle housing for '02 125SX
Just purchased a 2002 125SX in exceptional condition, except for a broken throttle housing that I didn't notice until I got it home because it was concealed by the rubber cover. It appears that KTM is pretty proud of them, because they want $80+ for a new one. Is there anything magical about them, or might a less expensive Japanese model work? I suspect that it's cheaper to buy a cable and housing for a Yamaha than it is for just the KTM housing. Shouldn't a Keihin equipped bike work with anybody's throttle?
I know that a 99 CR 250 cable is an interchange for a 200 that gives you a 4-5" longer cable so maybe it will work. You can buy aftermarket throttle tubes from motion pro also.
A honda xr80/100 throttle housing will work if you use the honda throttle tube also. The only drawback is you end up with a slower throttle (which I happen to like on 250sx).
