James Dean parts ?
i currently have a ocemn needle and i assume a stock needle jet since there are no markings on it anywhere. it is a fcr 40 carb from a 02 - 04 crf450r i believe. 00AAQA17 is the number stamped on the side of the carb. i need a new needle and needle jet but do not know where to get the ocemn needle. i can get the jet from the honda dealer. do you have a needle that would work for this. it seems that white bros. has every needle but the emn needle. thanks JD.
i have a ltz434 with a fcr40 mm carb. altitude is 750 ft.
motor mods are
tc full porting using his cams
full rossier exhaust
white bros. cdi
athena 434 kit
fcr 40mm carb jetted as follows
pilot jet 42
main jet 160
ocemn needle 3rd clip down from top
leak jet 55
fuel screw 2 turns
