05 YZ450 fork issues
My forks are clanging at the end of the rebound, when the forks are fully extended after a quick compression. Just started doing this. I had the fork seals changed and they aren't leaking. I rode it several times after they were changed and they started doing this at the end of the last ride. Can to much rebound cause this? Other than that clanging they aren't bad. Scary because you can feel it in the bars. Any help would be great. Thanks
I would take them back for them to check it out. Just to be sure nothing is loose.
I'll 2nd that. The '05 YZ KYB's were a little more difficult to build right so I would also advise to get them re-checked.
doc
Well, after rechecking I found the problem. Looking in the wrong place. Steering stem lock nut was loose. Really loose. Duh!
