TT350 carb overflow
Ok, I've had it with these carbs! But since I have no choice does anyone have an exact measurement for the float? I take a plastic tube from the overflow bend it without kinks to up near the choke then the fuel level should be 6mm down from the bowl to carb joint. I have it right on 6mm and if you rock the carb in your hands it will drip fuel out the overflow. Needle and seat are new. Should I just keep lowering it till it doesn't drip or does rocking it in your hands move it more than on the bike could?
Also as a side note my bike has oversized SS valves big header and a bit higher compression is there any reason why you would need to run the valve clearences a bit looser than normal? Mine are set looser from mechanic and I was wondering what the advantage is?
