Husaberg Valves
Hi everyone,
Need a little help. I recently bought a 06 FE450E, but the manual does not says anything about the valve adjustment.
Does somerone knows how to do it or where can get more info?
Thanks
:thumbsup:
When www.husaberg.org get done with it's server move you should visit and search through the site. There's tons of information and they have a download site that has video of how to do valve adjustments.
If you can't wait for the .org site to come back, review the valve setting information on this site or on KTM talk, it is essentially the same since the KTM RFS motor is a copy of the Husaberg motor. Husabergs are set just a tick tighter.
Basically...
Motor at room temperature. Engine at top dead center. Remove valve inspection window covers.
The manual says the valve gap should be 0.12mm but anything within 0.08mm and 0.12mm is in spec.
Husaberg.org is going thru a server upgrade at the moment.
