Overheated
I have a 03 YZ125 that i rode today at open track. I pulled off and it smelled hot so when it cooled i looked in the radiator and saw there was no coolant. It leaked all over the front of the motor and i dont think any went out the overflow tube. It looks like it leaked out the seam where the right side case half meets the case cover. :thumbsup: But im not sure thats where its leaking from. I can do major motor work but i dont really want to.
Maybe one of the rubber tubes are broken/coming off?
That's what I was thinking. Check out the hoses first. Hopefully it'll be an easy fix.
My friend thinks it might be the water pump seal. I just wanted to see what you guys think before i tear into it since i mostly work on air cooled engines.
If you can't find the leak then it could be a bad head gasket. :thumbsup:
Your oil would come out milky, if that was the case.
Its not too bad, only the base gasket. Its time for a new topend anyways.
