XR-200 motor conversion
Ok everyone this is going to be a little complicated but hopefully with everyones input we can get it working no problem. I own my own motorcycle repair shop. well anyways A guy dropped off a 95' xr 200. The piston is seized so i will need new piston, pin, all that stuff, bore out the cylinder and replate and hone it etc. Anyways i was wondering if there is just a whole different and more powerfull motor i can basically just drop in tehre and bolt right up, with little or no modification. Any help would be appriciated as with what would be the easiest waty to go about this.
Thanks Todd
ahhhh. zongshen and lifan make a motor. or the old atc 200 3 wheeler. or any model xr200 except the 84 and 85 should be real close to a perfect fit.
