2000 KTM fork help
I just posted in the suspension forum but thought I'd link it here incase someone has an answer but doesn't visit the suspension area.
http://www.thumpertalk.com/forum/showthread.php?t=409935
Thanks
hold the top cap up...then pull down the spring, you will see the jam nut.
put a wrench on the jam nut, and remove the top cap. remove the spring.
slide down the dust seal, remove the retaining ring, the seal can then be removed by quickly sliding the two tubes apart.
dave
