HELP! FCR-MX disaster!!
I don't know what I did wrong, but I did it good. I took my fcr-mx apart to check the needle clip position. I took the top cover off, and rotated the slide actuator to remove the slide from the carb. Apparently you shouldn't do that because now when I put the slide back in it will not close completely. I'm bummed and stumped, not to mention stranded. Please help me out!!
Thanks in advance!
naw, I screwed up the ap cam linkage; got it overcenter. Had to tear the actuator shaft out to get it all right. Could've used 2 more hands to hold all the springs and things, but I got it. Thanks for your input; it's nice to know help is always out there!
Note that needle adjustment does not require slide removal.
