is my plug fouled or am a crappy carb mech.
well there it is. I put a full yosh and stage two jet on my 06 drz sm... it ran really well for a week or two, then i started having problems. sputtering and losing power and such, and some popping. all i know about air/fuel is that it pops when its lean and turns the pipe blue. and it turns the pipe gold and fouls the plug if its too rich, right? so i was assuming it was running lean, so i started messin with the fuel screw and all that crap. now i thought i had it but it still runs a little funky unless im just on the throttle . so even id=f i run it + rich, or + lean, no matter which way i go it still sputters a bit... so does all this mean its passed a jetting concern and its now a spark issue? this is embarrasing, but ive never taken a spark plug out, and i dont want to unless im pretty sure thats the prob...... help!!!!!
crap, i cant remember exactly... i followed dynojet reccomendations for stage two... does that help? 155 main , second down on the needle, 3.5 turns out( now set at 3.25 turns i think) it ran good for a while, maybe a little rich.
ive got it so that there is no popping on decel at all, but if im just barely on the throttle in higher gears, it surges, and sputters. I literally have to be at full throttle to maintain a steady speed through corners( the steady speed being fast as fu@#) its no prob on really tight twisty stuff when im constantly on the throttle, and shifting. but if im in any sweepers i cant keep a mellow speed... it keeps lurching, and sputtering... bahhh... maybe ill just take it to a shop.
anyone? the sm is my only transpo right now. my truck is in the shop getting thousands of dollars in work done.
did you reuse all the stock needle spacers?correct order?2nd needle clip?from flat end?
trying to eliminate the decel pop will make you overly rich.
I used a dynojet needle, second groove down, and other than the main 155, everything else was stock parts.oh yeah and im at like 25 feet above sea level
is the needle retainer the e clip? or the actual little housing thingy?
