DR650SE Air Box mod
I might be uninformed....... I just rejetted my carb to a Dyno Master 170 jet, added Supertrapp ISD2, and a 14tooth front sprocket. The changes showed immedieate increses in torque and power through all gears. I am totally impressed!!! My question is why people are destroying their aqir box for the increased air flow. I have a 2005 and all I did was remove 4 screws and take the cover off. The area of the cover removed seemed more then 2 2" HOLES. Am I missing something?
Just stay out of deep mud puddles or streams and you should be ok
Less likely to take big gulps of water thru the top than the side
BTW, did you take off the little captive nuts?
If not they are probably gone
OK, holes make sense on top of the box now that you bring that up. Thankfully, we have this message board to exchange info!!! What Captive nuts are you talking about?
There are four little nuts that the cover plate screws to(square in shape). They just pop out. Make sure you take them out or they will be gone after a few rides.
