removal of the water pump
I've never done it on a crf250, but I did have to swap out impeller shafts on my cr125. The manual made this job very easy. Do you only need to remove the impeller or the entire shaft?
I could very easily be wrong but something might be reverse threaded.
You are correct. Put it in gear, step on the brake and turn the impeller clockwise to loosen.
