Tune up specs for 1973 XL100 and 1979 XR80
Does anyone have the tune up specs for:
1973 XL100
1979 XR80
Valve intake and exhaust
Point gap (points, yikes!)
Spark plug and gap
etc.
I picked up a couple of project bikes.
Step 1 is tune up.
Sources for points and condenser appreciated too.
Thank you in advance,
Kevin
The following is from page IX of the Clymer book, Honda 100-350cc OHC singles 1969-1982.
100 and 125 Valve clearance. Intake 0.002 Exhaust 0.002
Spark plug type, 100-125 and 175 (through 1976) NGK D8ES-L gap 0.024-0.028
Idle RPM CB100-CL100-SL100-XL100 --- 1200 +-100rpm
Contact breaker point gap 0.012-0.016
Sorry, can't help you on the 80.
XR80:
Valves: 0.05mm (.002 in)
Compression: 170 psi
Plug: ngk c7hs
Plug gap: .6 -.7mm
Points throw them away and get a CDI!!!!!!!!
Ok, Points gap .3 -.4mm (0.012 - 0.16in)
Thanks for the info.
Is is possible to upgrade an older bike to CDI? If I can do that for the 79 XR80 or 73 XL100, that would be great.
Also, were is a good onlines parts phish?
I need to see if the clutch basket on the XL100 can be replaced by a newer XR100 basket.
Honda reuses parts over and over.
Socalxr can help you with the CDI conversion, as I don't know about the smaller bikes. The only small bike I have with points is a 1978 Z50, and it runs good enough for what I need it for. I did convert a 1975 XL350 over to CDI. Simple, but costly if you use new parts. If I remember right, mine was about $300 all used parts. The main cost for the XL350 conversion was the stator. It has to get rewound from 30 volts to 90 volts. I know that sounds like high voltage, but I've never seen a bike start so easy, vintage or modern. It will start with-in half a stroke of the kick starter, first time, every time.
I just do XR80/100's. It's pratically a direct bolt-on. I don't have any experience with any other bike.
Everything bolts on. you need to grind a little piece that stick up under the stator and make a bracket to hold the Black box and coil. It will bolt under the tank. The cost is about $100-$175 off ebay. You could get a step key, but it's not neccessary.
