Stator testing - ????
I was hoping someone had the resistance figures for the stator on a 1975 XR75. I've got the bike back home after the charade at the Honda shop (see earlier post), and I've got a friend's multimeter/ohmmeter, so I was going to take a stab at it to see if the stator needs rewound or is just plain bad.
Also, what wires should I hook up the ohhmeter to in order to get an accurate reading? How do I know what's "acceptable" and what isn't, in terms of resistance?
Thanks.
:thumbsup:
In my Clymer manual, It states that Honda does not provide Stator coil resistance specifications for the XR75. Although, the xr80/100's are 0.576-0.704 ohm. This should be close enough. Any lower, get a new stator. Any higher clean your breaker points. Flywheel needs to be at F. Use the black/white wire and a ground.
