z50 pipe
Sure, as long as you don't mind the smell of burnt flesh emanating from your right inner thigh area, and have a high tolerance for pain...
The CRF/XR50 stock pipe will not fit behind the right rear shock of the Z50R. In order to use it, you have to mount it to the outside of the top shock mount on the right side, and keep in mind that the pipe is there, otherwise, reread the first sentence.
I did it as strictly as a temporary measure, until I received the aftermarket pipe made for the bike.
well what was the pipe and where did you get it...also does it need those spaces because mine got tlost and if so do you know where to find it
You need an exhaust gasket, it goes up into the head just before you bolt the exhaust up in place.
The pipe I used was from an '03 XR50, it will bolt right up to the Z50 engine, but you have to fasten it to the outside of the right rear shock, it will not fit behind the shock, like the stock Z50 pipe does.
