raising a bike
i would like to make the seat hight on my cr80rb taller, is there any way i can do this without buying a part?
if u could possibley get an old dirt bike seat from the junk yard and then cut the bottom portion of the foam to the desired hieght then put it under the seat foam
on your cr80 and put the seat cover back on. make shure that u use some kind of rubber cement or something to secure the to pieces of foam together.
I have a question on the adding more/taller foam. Wouldn't you need a larger seat cover? I thought about adding foam to my stock seat, but it looks like the stock seat cover has just enough "excess" on it where the staples are.
My guess is that you will have to have a seat cover, the stocker won't cut it. :thumbsup:
