breather kit
On a stock motor ....No But on a Modified motor Yes the relief of Crank pressure will help the motor spin faster and put less strain on parts.
After using one for awhile, then switching back to a crankcase only breather setup, I'm not a proponent of extra breathers. If your motor is producing enough pressure in the crankcases that it's noticable when you wind it up, or you're popping seals, etc, something else is wrong with the bike that should be found and corrected.
