Fredette chain guide
got the chain guide for the kxf. Now the tension is tighter on the chain, I don't think the oem guide held it up so high. Question is how diffrent is the chain tensioning specs now? I also herd the 250 & 450 are the same chain guides, maybe I got the wrong one. Does anyone else run these "shark fins'.
I am using the Fredette with no problems. I set the tension the same way I did with the stock guide and it is working well.
I haven't had any problems with the Fredette setup since I installed it. It was a little noisier at first due to the plastic slider, but it quited down within a few laps. It also wears much better than the stock rubber.
I'm running the fredette with the stock rubber upper cut out and put inside there to quite it down.
