oil question..
On my 05` crf 250 there are to oil plugs on the engine, can any one tell me why?
Read this for some background info: http://www.thumperfaq.com/oil.htm
Engine and trans oil are seperate.......this is one of the great selling points for these engines (Honda 250/450's). Can't believe there is anyone out there who doesn't know that. How many hours have you put on it without an oil change????
:thumbsup:
First of all, this is my first thumper, and second ive only been riding 4 hours on it. So that is why I ask(time for oil change)... I know about the seperated oil chambers(so the small metal pieces gets in the oil filter and not the crank shaft, Genius!!) Should I put SAE 10W 40(Motul) in both? or is the engine better of on something else?
Cheerio`
Sorry I insulted you, but you really didn't phrase your question very well at all!
In the trans, you can run a motorcycle specific API SG/JASO MA engine oil, or one of the trans specific lubes (like you would in a 2-stroke trans).
In the engine, you have additional choices. I would run a API SG motorcycle oil that is either JASO MA or MB (if you can find one).
Which Motul product are you considering??? Motul oils have a high percentage of ester synthetics, which makes them excellent oils! I would probably run 5100 if I were running Motul. My personal choice is Maxima Extra, also an ester synthetic for both the engine and transmission sides. http://www.maximausa.com/technical/lubenews/LubeNews2002.pdf http://www.scooterhelp.com/genmaintain/crankcase.oil.html
One thing to consider, you are still in the break-in period, and although this is controversial, some would say you need to stick with a petroleum oil during break-in.
1.In the trans, you can run a motorcycle specific API SG/JASO MA engine oil, or one of the trans specific lubes (like you would in a 2-stroke trans).
2.Which Motul product are you considering??? Motul oils have a high percentage of ester synthetics, which makes them excellent oils! I would probably run 5100 if I were running Motul.
3.One thing to consider, you are still in the break-in period, and although this is controversial, some would say you need to stick with a petroleum oil during break-in.
1.How about the bel-ray Sae 80(Gear saver)In the tranny?Or is this too thin for an thumper?
2.Not sure what it`s called, will check it later.
3.I may have phrased myself wrong again, the bike is one year old. I just bought it from a guy, I have only been riding it for about 4 hours.
Buy any good oil that has a MA rating and use it in the motorside. If you ride it long and hard use the heavier grades. 15W,20W-50. 10W-40 is good for general use. Change it alot regardless.
In the tranny side the choices are huge from ATF to specific clutch fluids. IMO I try to find a good oil designed for the clutch that is light enough to shift good and also hold up to the heat of the clutch slipping. Change this oil also alot....
Thank you guys for the great inputs:) you sure have been too alot of help!
Cheerio`
