CRF450 Clutch/transmission Question.
I buddy of mine just bought a used 05 450.When he got it home he thought he would change all bodily fliuds and when he did the trans oil came out silvery colored.So he refilled it,drove it and dumped it again and it was still the same but less silver in it.He freaked because he thought it was chewing up gears.He caled the original owner and the guy says it's normal because of the aluminum clutch discs.Is this right?
Sounds normal....
My 05 trans oil has been the same way since I bought it.
Just make sure it is not milky (mixing with water/coolant).
If you do a search you will find many others have had this concern.
