Oil Change Question???
Are the crush washer on the case oil drain and the crush washer on the oil drain on the frame the same part? The stealership says the case one works on the frame drain, but it fits the frame drain bolt looser than a 50 year old WV wh:censored:re.
The micro fische say that they are the same part...help?!?!?!
i would think they should have a different o.d. & i.d..
the bolts are different sizes. frame bolt being smaller.
Not the same parts, crankcase drain gasket is part 09168-12011
and the frame drain gasket is 09168-10002.
