Can you use a FMF Power bomb header with a stock Exhaust?
You can run the PB header with the stock pipe, but you'll need to fabricate your own gasket at the joint - I used 2 layers of aluminum flashing for the gasket and some high heat red liquid gastet to seal it (both can be found at the Home Depot).
Works fine and it does help the bottom.
If you cut it and shape it right, you can use it along with 2 sided tape and some zip-ties to make guards for the upper part of the frame too. I use it along with Works Connection frame guards for my 02 WR250F. I've had them on since 02 and I haven't had to replace them yet.
