Oil capacity
On my 03 YZ125, next to the oil filler hole there is a marking that says 650cc. In the manual it says Periodic oil change - .65 L, and Total amount - .70 L. How much trans oil do i put in? Ive been filling it till oil comes out the check-hole.
650 cc is about 2/3rds of a quart. Fill it w/ that amount or the way you've been doing it. Make sure if you use the screw hole that the bike is level on a stand. Change that oil often! :thumbsup:
650cc's for periodic oil changes and 700cc's if the motor is dry (ie. brand new or just rebuilt the bottom end).
I dont know about your year YZ, but the oil check bolt is not to be used on mine. Get a measuring cup, fill it to 650cc's and pour. Ride, rinse & repeat.
