what is the valve clearance for a Husaberg FE501?
aout !/8th of a turn will usually do.dan.
I use this method myself. :thumbsup: It took me a couple times to get the right feel for it though.
It's my understanding that anywhere between 0.08mm and 0.12mm is within spec.
At least that's the spec for 03+ model Husabergs.
The 1/8th back off turn on the adjustment screw is another option.
Last Time I Tried That I Couldnt Get The Bike Started,Found The Treads On the Nuts To Be Very Tight,So When I Thought That The Adjuster Was Pushing On The Valve It Was Actually Miles Away. I Use The Motion Pro Feeler Guages,Quite Easy When You Get The Nack Of It,Even In The Tight Space Of The 2001 Cover.
