carb rebuild question
ok, kind of a stupid question because i should have paid better attention when taking apart the carb but- there is a small hole (~3/16 dia) at the bottom of the slide valve, where the link arm bracket screws down (covering the needle clip). this hole should remain uncovered correct?
i'm not sure if it is even possible to put it back together with the hole covered, but i figured it can't hurt to ask. any info will be greatly appreciated, thanks!
I have an almost new stock carb for an XR4.....was replaced with a pumper. I can ship it to you if you like. What is it worth to you?
