Shock Shaft Travel
Anyone know how to get ahold of the spec for shaft travel on a stock 2002 XR400R shock? I believe it's a Showa 44mm unit.
I'm running a light spring based on preference and need to know the shaft travel, including rubber bumper compression, to calculate the amount of preload I can run before coil bind happens. Already got the spring specs for travel etc.
Anyone know this... or know if these specs are anywhere on the web?
Pull the shock off and pull it apart, remove the bumper and measure the travel . Some things have to be done the old fashioned way .
Or, you might try calling XR's only , they might know .
Yup... was hoping to avoid all that, thank you very much. I'm sure this spec exists somewhere.
