2000 Xr200 Fork Air Pressure
Need to know what air pressure to run in the forks in a 2000 XR200 for somebody weighing about 200 lbs? Seem way to soft now.
Any ideas :thumbsup:
If you don't know, go with zero. The pre-1990 XR200R's were set up to hold under 10 psi. Most fork valves are for releasing air pressure, but the older XR200's were designed to use a little air pressure.
Mind you the reason is not to hold up the bike. That is what the springs do. Air pressure makes the air pocket build up air pressure faster. It is for bottoming.
None.
If you want to improve your XR200 suspension, there are lots of things you can do. Search it on this forum, and you will find TONS of threads on it.
