CRF450R triple clamp on my SM?
My buddy gave me his old(few months) applied upper triple clamp with risers for fat bars. Will these bolt up to my 06 DRZ400SM?
measure the outside diameter(OD) of the upper fork tube(e.g. 46mm). measure the inside(ID) of the top triple clamp. and if they match you should be fine.
--keith
most likely it will not fit; the crf and drz frames are very different..... but you can try.
good luck..
the offset of the steerer tube is needing to be matched up between the top and bottom triple clamp. if you can score the right offset clamp as your bottom one, you should be fine. otherwise you won't be able to install the top clamp.
--keith
Thanks. I will measure it tommorow and see. If it doesn't fit I will just use the risers.
