2003 DR-Z400S Stutter??
I picked up an 03 DR-Z400S with only 100 miles on it. It has been sitting for a few years so I'm expecting that it needs a carb clean???
If I give it a ton of gas in each gear it stutters/hesitates. If I gradually give it gas in each gear (but what is the fun in that) it does not stutter or hesitate. I've put 50 miles on it since I got it and I thought it would clean itself out.. but it is still doing the stutter..
Any suggestions?
If it has been sitting for a while I would clean the carb (jets), drain the gas tank put in fresh fuel, try a new spark plug. Also would consider changing the oil too and check all the other fluid levels.
jetting, mine did this when I first got it brand new from the stealer because it was jetted for 3,500 feet below my elavation
If it has factory jetting, it is WAY lean for Colorado. They're too lean for Death Valley to meet emissions.
