cam mods
Hi
I am new here and i just want to be sure about a thing that i eared before.
I eared that if you was changing intake cams on a z 400 for a hot cam that you could put the old intake cam that you already change a the exhaust cam place and it will be better than a exhaust cam.
Do i dream about that or its true
Thanks for answer and sorry for my little poor english
Not sure if it is any different, but yes you can use an inlet for the exhaust.
The tricky part is dialling the cam in, as all the timing marks on the cam sprocket will be wrong,
Neil. :thumbsup::applause::applause:
you also lose the auto decompression, right?
here are some cam specs from the yahoo drz group, it's not obvious to me the intake moved to exhaust is better. The lift is greater, but duration shorter
Clearly the E cams are better than the S
Lift and duration for various cams for DRZ400 engine
S&SM Int. .334 lift 227 dur Exh. .323 lift 243 dur
E&K Int. .351 lift 227 dur Exh. .366 lift 243 dur
yosh Int. .354 lift 236 dur Exh. .366 lift 242 dur
HC stage 1 (new) Int. .358 lift 238 dur Exh. .358 lift 238 dur
HC stage 2(was stage 1) Int. .377 lift 243 dur Exh. .377 lift 243 dur
Those figures actually came from here eddie (burned) on this board :thumbsup:
There isn't enough of a gain to go through the effort
Thank you for the fast answers.
I really enjoy to be on this site and you guys just making a very good job here
that is inof i posted here that has been stolen.
Bastards!!!! is the info still correct?
