KLX400R jetting question, burned!!!
This week-end, I will be installing a full RS-3 YOSHI pipe on my 03 KLX400R
I also have a K&N air filter and removed snorkle
I will be using the stock OBDXP needle
I have 165,168,170 main jet available
Altitude here in Montréal is around 100 pi.
I was thinking of starting with 168 main, 5th groove and 2½ turn out.
Burned, what do you suggest as starting point.
Thanks
Yves
Yves
Thanks, what is the stock main size?
I'm confused, my service manual said 165, my dealer say 162.5 and I've seen 142 somewhere else.
I assume it's 165
Thanks
Yves
By the way, I've been told that the K&N is one of the worst air filter for our bikes. Wich filter do you consider the best, stock, uni?????
I will start with the 168 and 5th groove and then see the results, might be a bit rich in the middle but I'll see.
Thanks
