Hole behind waterpump leaking oil
Your water pump seal is leaking and needs to be replaced. The seal has coolant on one side, oil on the other and a leak path in the middle so a bad seal shows. Do a search here or on ktmtalk.com for instructions on how to do this common repair. The fix is relatively cheap and simple, but if you do it wrong you'll have to repeat it :thumbsup: . There is a member named Jeb on both websites that has a nice "how to" linked on the bottom of his posts :applause: .
Good luck!
