Antigravity Batteries Product Giveaways - ENTER NOW! Read more... ×
MrNew head and piston wrapped up: Hard to kickstart!?!?!
Thanks everyone. The narrow down my search, does the fact that it does kick eventually rule one of the possible causes out?
No, mine would kick eventually, just had to coax it a bit first. It could also quite possibly be the compression release mechanism is out of adjustment.
Hmmm, ok. But I never touched that end of the cam...
Might be just tight with the new piston and stuff. How many times have you turned it over completly??
Ive only kickedit over about 10 times. Was too hard. With kcick starter in top position I would kick andit would move like half an inch. Move it back up to top and with a lot of pushing it would go.
first off if there was that much efort you should have not tryed to finish kiking it through if the cam timing were off enough to have the valves touching the piston there toast now to eliminate some of the possible poblems you may remove the clutch basket and see if the engine rotates smoothly .
:thumbsup: Meaning regardless of what the cause is I need new valves now??? Im going to be sick....
not if it is your clutch that was hanging up you need to determine what is happening .rmoveyour clutch cover andtry to roate the crank by the crank bollt with a allen whrench if it does not turn eazy then remove your clutch hub and atempt it again if the crank still comes against resistence then its in the head and valves .
Have you confirmed the timing marks yet? This should be your next step.
Compression release is not adjustable on the 250. It's dependant on cam timing, and exhaust valve clearance.
At the point where you can't kick it over, are the valves open or closed? This should be very easy to see with the cover removed. If they are closed, you have a decompression issue. If they are open, you have bigger problems...
if your timeing is off u can put carb cleaner in the the ports to see if they are leaking i would checkin timeing if its off just correct it and try it, its easier to do that and see if it starts then to pull it all apart and check it and find out its ok and have to buy new gaskets and everything else that gos along with it
Before work only ahd time to check right side crankcase cover allen. It turned fine with the normal amount of resistance after one turn.
Define "big problems"... toasted valves?
Ok, if you can easily turn the crank over from the right side inspection / timing cover opening then the problem can't be in the valve train and timing or in the clutch. This is all engaged and rotating freely. The only thing left would have to be the kick start mechanism itself (since the kickstart gear is also driven by / drives the clutch gear)
Please verify that you can freely turn the crank over 2 complete revolutions not using the kick start lever as I assumed from your post.
dude its not like u where full throttle when it happened just check clearances and timing that will tell u what u need to know
dude, :thumbsup: , when someone like RHC tells you something its to be respected. Valves were defintiely in clearance - spot on actually.
This project has taken 2 weeks at an hour-here- and and hour-there, between work, soccer games, family engaements. :thumbsup: I dropped it off at the dealer. Im out of town a lot next week and have no more time to devote to it, witrh some races coming up after that. They felt on first thought that it was autodecomp issue. I will reprot back what they find.
Appreciate everyones support!!!!!!!!!!!!!!!!!! I know throttlejockey has to be giggling and shaking his head a little :lame:
Appreciate everyones support!!!!!!!!!!!!!!!!!! I know throttlejockey has to be giggling and shaking his head a little :ride:
:lame::p:bonk::eek::bonk::mad::worthy::worthy::eek::eek::eek::eek::lol::prof::cry::D:naughty:
Which part is naughty: having taken it to the dealer? I know, I know....
uhuh... the dealer....
Appreciate everyones support!!!!!!!!!!!!!!!!!! I know throttlejockey has to be giggling and shaking his head a little :p
No giggling, but my neck hurts.
Kind of hard to follow exactly what you did in reference to turning it over. Did you turn it over after you got the head and piston put in with no problems?
Did you finish installing the clutch after that? If so, then it's probably clutch related.
Are you sure you're not making this stuff up? :thumbsup:
Are you lacking attention or something? :lame:
Just checked that a few minutes ago. What would be wrong with it to cause that? I took it back off, turned the screw clockwise to retrack shaft, held it like that while I replaced the tensioner to head, then released it. Still reall hard to kick.
If the engine feels continuously "tight" throughout the entire revolution (no "loose" spots), it sounds a lot like the tensioner lifter issue we had when we reinstalled our tensioner without retracting it first. Ours also make a "rubber binding on metal" sound when it did move. Are you sure the cam chain is properly centered on the chain guide and tensioner (6 and 2)? Have you tried partly retracting the tensioner lifter to see if that helps? Did you have the lifter fully retracted while you installed it?
  • Similar Content
    • By Kadensmith44
      I’m wanting to powder coat my bike but it’s all new to me. I’ve got a powder coater picked out that I’ve heard is good for what I’m doing. I’m not 100% what kind of sand blaster I need and what kind of media. I have also heard you can’t cook in the oven after you’ve baked your parts is that true?
    • By luke8500
      Hi all,
      I have a 2004 honda crf250r and it wont start hot at all. The motor was just rebuilt with a new cylinder and piston. The valves were just adjusted. It will start cold in 1 or 2 kicks with choke but as soon as it gets hot it wont start. If you bump start it the motor will just turn over without starting.  sometimes it will start. It runs great until you shut it off.  im thinking its either a fuel issue or an electrical issue. Any help would be greatly appreciated.
    • By SandSoldier
      Hello! This listing is for my 2007 Honda CRF250R dirt bike. Last winter I spun the rod bearing and just recently finished rebuilding it. Selling to fund new bike. I am currently the second owner.
      Current registration valid until 2020, pink slip in hand.
      Fresh parts:
      -top end kit: Wiseco; forged, moly skirt coated, 12.9:1 comp ratio (new wrist pin, gaskets, etc)
      -cylinder: new OEM
      -bottom end kit: Wiseco; (new bearings, seals, etc)
      -oil pump: new OEM
      -head studs & nuts: new OEM
      -fresh oil and filter
      -all tolerances checked in top end
      -valves adjusted
      -carb adjusted
      Note:
      *rebuild was done by my dad (master tech at CAT) and I (4th year mechanical engineering student)
      *has maybe 15 minutes on new parts, IT HAS NOT BEEN PROPERLY BROKEN IN YET
      *I have email receipts, pics of rebuild, and old parts as proof of rebuild, just ask and I'll show em off
      Other parts:
      -90% tread on front and rear tires
      -excell takasago front wheel
      -custom aluminum skid plate
      -wrap around hand guards
      -spark arrestor
      -kickstand
      Feel free to ask for any more specifics or pictures!
      LOCAL PICK UP ONLY
      Thanks!
    • By Matt Ray
      Okay so the title is a little vague.
      So it was having trouble idling and even starting when I first bought it about a month ago for $2k.
      So I did a rough clean of carb, looked up on YouTube, Forums, Etc on how to do it. I only cleaned jets with carb cleaner and sprayed around the float bowl area and such, so not too extensive.
      Did that and I took it out to a park, It would start up right away mostly, few kicks sometimes, but when I got it started, I had to keep the choke on. Right when I was ready to go fast and go up to 3rd and 4th gear I'd switch it off and it would work fine and sound fine and everything, but when I slowed back down and coasted around 1st gear i'd pop it back out again because it sounded like it was going to do. I have some videos if people would like me to link to them.
      So after that I decided to take it apart and replace spark plug with OEM NGK R0409B-8, replace main jet from a old 170 to a new 170, replaced pilot jet from a old 40 to a new 42, and kept starter jet the same just made sure that wasn't clogged, ordered a new adjustable fuel screw and used that.
      and it was still having a little bit of problems! I just started up today and the day before today. It would run only with choke on, if i twisted throttle in neutral it sounded pretty good, no gun shot noises or anything, pretty smooth.
      If I tried to take choke off it would die immediately. So I started it back up again, took around 6 kicks.. So again with choke on it sounded like it was starting to lose power and RPM's would drop so I'd twist throttle a few times and it would stay idling.. then after a small amount of time, start to sound like its about to die again... so I would rev it up again, and repeat..
      Fuel line isn't clogged, flows fine.
      I tried fuel screw everywhere between 1 and 2 turns out..
      I checked valve clearances, and I'm no expert but from the videos I watched the slipped underneath intake and exhaust with only minor force.
      So I'm lost..
      Maybe float bowl is messed up? Should I just do a COMPLETE carb rebuild from videos I've seen on youtube, like this one -> https://www.youtube.com/watch?v=3AXb9UprT30? Or what?
      It's getting annoying taking it apart all the time, I jsut want it to start up quickly and run well!!
      Thank you!
      Austin, TX, Elevation 600ft, where I ride its around 900ft
    • By Bryan Bosch
      WASHINGTON, D.C. – August 16, 2018 – (Motor Sports Newswire) –
      Honda Recall Summary:
      Name of product: CRF250R Off-Road Motorcycles Hazard: The clutch outer can break, posing crash and injury hazards. Remedy: Repair Recall date: August 16, 2018 Units: About 3,200
      Consumer Contact: American Honda toll-free at 866-784-1870 from 8:30 a.m. to 4:30 p.m. PT Monday through Friday or online at http://powersports.honda.com/ and click on “Recall Information” at the bottom of the page for more information.
      Honda Recall Details:
      Description: This recall involves all 2018 Model Year CRF250R off-road motorcycles. The recalled motorcycles were sold in a red color. The names “HONDA” and “CRF250R” are printed on the sides of the motorcycle. The model name and model year are printed on a name plate label located at the front right top of the frame, near the steering head.
      Remedy: Consumers should immediately stop using the recalled off-road motorcycles and contact their local authorized Honda Powersports dealer to schedule an appointment for a free repair. Honda is contacting all known purchasers directly.
      Incidents/Injuries: American Honda has received 19 reports of clutch failure, including two that led to engine lock up. No crashes or injuries reported.
      Sold At: Authorized Honda Powersports dealers nationwide from November 2017 through July 2018 for about $8,000.
      Manufacturer(s): American Honda Motor Company Inc., of Torrance, Calif. Manufactured In: Japan Recall number: 18-759 This recall was conducted, voluntarily by the company, under CPSC’s Fast Track Recall process. Fast Track recalls are initiated by firms, who commit to work with CPSC to quickly announce the recall and remedy to protect consumers.
      The U.S. Consumer Product Safety Commission is charged with protecting the public from unreasonable risks of injury or death associated with the use of thousands of types of consumer products under the agency’s jurisdiction. Deaths, injuries, and property damage from consumer product incidents cost the nation more than $1 trillion annually. CPSC is committed to protecting consumers and families from products that pose a fire, electrical, chemical or mechanical hazard. CPSC’s work to help ensure the safety of consumer products – such as toys, cribs, power tools, cigarette lighters and household chemicals -– contributed to a decline in the rate of deaths and injuries associated with consumer products over the past 40 years.
      Federal law bars any person from selling products subject to a publicly-announced voluntary recall by a manufacturer or a mandatory recall ordered by the Commission.
      Source: Consumer Product Safety Commission
