Who can help me jet?
I can't seem to get a straight answer anywhere from shops or people...
Bike is a 05 CRF230.
Mods:
UNI air filter (restrictor removed)
and exhaust baffle removed.
They also come kinda rich from what I gather.
I would love to get this thing tuned, but what size should I run for this climate?
Any help would be great.
So I'm seeing two ppl with esentially the same mods at the same elevation running different setups. http://rickramsey.net/CRF230Fmods.htm
Also read to do 120 main, 45 pilot, stock needle 4th clip.
Then here:http://www.off-road.com/dirtbike/projects/crf230f/1/
they say-
Main: 132 - Part # 99113-GHB-1320, Pilot: stock is 42, Needle: Honda Power-up kit part #16012-KPS-921 (clip in middle position), Pilot screw: Stock (5/8th turn out), Standard Float level
In a thread I started a while back i was told most people do 124/45/4th setup.
Exactly, and the info varies depending on where you look.... That's why I'm in the regional section hoping someone will have first hand info for this climate. :shrug:
