Yosh Rs-2?
that would be cool if this is legit
So what is the word?? I was ready to buy the yosh ti pipe untill i saw this anybody know anything???
I imagine it will be a while until someone can dyno it against the Yosh Ti. Still has the potato I see. :lame: Maybe just a redesign with better packing? I would think they would call something new like that the RS-4 :thumbsup: Oh well, Japan is kind of a strange place anyway. :p
i was just curious if it was a typo or not...
could someone from the thumpertalk store find out if this thing is coming out and what a price is?
It's a very nice looking exhaust but from what I can gather it's among their most quiet and heaviest,with all the extra packing they put in.You don't get the Ti muffler either like the super light TRC series which I think is still their top dog for the DRZ.
SS header and mid..... oval can......but if they wanted quiet pipes why is it just for the SM?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
