DR-Z torque specs
Can anyone tell me what suzuki's suggested torque specs are for the front and rear sprockets on a dr-z400s. Thanks.
Front = 110 N-m or 79.5 lb-ft
Rear = 30 N-m or 21.5 lb-ft
Post your e-mail address and I'll send you an excel file that has the various torques.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
