broken oil drain bolt in a 2005 525exc??????
I have a 2005 525exc and the drain bolt in the bottom of the motor is striped. Anyone have any ideas on what to do?
You"ll have to chisel it out. Sorry. There are aftermarket bolts to replace it with. If you can"t find anything with the search button go to KTM talk and do a search. Plenty of answers for this one over there. This is a very common problem. Be sure to use an anti seize when installing a new one. Good luck
If there are no aftermarket bolts and it as an odd size (i.e. no hardware store will have this size) why not retap it to a different more common size once you get the old one out?
You can order a replacement from Brap or Enduro Egineering. Probobly made by the same people.
Thanks for the answers so far. But the drain bolt is still in the motor. Its not the threads that are striped, its were the wrench goes in the end of the bolt thats striped. The plug is stuck in the case. I thought about drilling a hole through it and using an "ez-out" but I am worried about metal shavings in the motor.
This method was used to remove a plug overtightened by the factory
07 250xcf mig welded the 8mm hex socket to the head of the drain plug.
tacked in three places, mig welder on low heat . 3/8 12" breakover wrench ,plug came right out.
Thank you, I will try that.
So the bolt is intact the head is just stripped? Why not try a set of Needle nose vise grips/clamps? I seem to remember on my 03 450exc that there is little room around the bolt due to the bottom of the engine cases but if there's room try a normal pair of vise grip clamps instead of needle nose, they will hold better. Then replace the bolt...
I cant get enough of the vice grip jaws on there. I tried that already. Thanks though. I will try welding the wrench to it and see if that works.
lol that things really in there hu? I thought the vice grips might be to big. I guess the weld would be the next best bet. I've ran into a problem changing my oil too. Not with the drain pug. Getting the freakin screens out. I stripped them both. I didn't use the wrong tool didn't do anything chancy. The freakin thing just stripped. I just left them in there for that oil change because I was short for time and they've never been dirty before, but I'm getting close to another oil change so I guess we'll see what I can do. hopefully they will come out with a little larger allen wrench and a lil tap from a hammer. I've done it before but never on a engine part. I'm a Little worried about making more work for myself but I wont know till I get in there.
Use an ezout tool for the screens. You should be able to find one about the right size then install new ones.
ez-outs only work if there is no (or not much) torque on the bolt. Otherwise they snap.
One thing I have had marginal success with is pounding the next size allen wrench into the stripped out hole. The pounding will help it break loose too if it is frozen.
Of course welding something on the probably the best way to do it.
Once you get it out:
I know this is a bit late but i have just had this happen to the small oil screen bottom of the engine. i used a number 10 torx hammered it in very carefully and hey presto out it came ordered new one job done. oh yeah this is a very common problem :mad:
Zipty Racing has a replacment bolt for the bottom allen bolt as well as magnetic drain plus for the rest of the bike. They are really good. there number is 760-244-7028
On my 04, what I found works best for loosening the bolts before an oil change. Is to ride the bike let it get to operating temp, then break them loose. Let the bike cool a bit, then change oil clean screens.
Well, this just happened to me also. I just recently paid over $100 for the local shop to change my oil also. Both screen bolts were factory tight. They must have missed (yea right) cleaning the screens during my break in check/cleaning.:mad:
This has been a problem since 2001!!!! Why doen't KTM switch the bolts. The allen at the bottom is soooo soft and way over tight from the factory.
:eek: :eek:
wit has a KTM
I read that you are supposed to give them a whack with a hammer/wood block to break the thread seating before trying the allen key.
Also to use a good quality allen key head socket and T -bar (not a L key).
Re-torque to the correct spec and use anti-seize.
:eek: :eek:
wit has a KTM
No, its a buddies bike that I was working on.
You can cut a slot in the bolt head with a dremel tool and use a hammer and cold chisel to loosen it.
The lower oil screen bolt is supposed to be tightened to 7lbs only!!!
I split 2 already myself - get after market with a bolt head instead of allen.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
