Which Oil to Use?
Just picked up an 01 YZ250F. Is there separate tranny and motor oils or is it all together? What oil/weight would you recommend? I'm in Jacksonville, FL. I didn't warm it up before I checked/added oil so now it is way too full. I need to drain it and add new stuff. Thanks
newb a thon
its all together
use a 10w-40 oil, like yama-lube or something
you could just look in the manual though
Do a search in this forum for "oil" or "best oil"
There is a lot of information already here....
RH
10-40 is good for all around. Check the factory service manual though, it has a chart for temperature conditions and proper grades to use.
Guest
This topic is now closed to further replies.
