Best Rev Box?
I see so many different brands and types of rex boxes, and ill be getting one soon, so which one is the best? I heard some there they takegawa was worth buying
none are worth the money but kitaco gets the popular vote
trailbikes coming in a close 2nd because it isnt so danm expensive!
There is a write up on another site. Yet to be completed. But basically speaking, if you have a stock low compression motor , or anything modified with low compression, then you wont notice anything. The only thing you will notice is the rev limiter is lifted, or set higher, depending on which box you choose. Your timing may be affected a little, but I think for the most part that you wont notice anything. I have a kitaco and can say when we installed it on our 70 motor it didnt do anything at all. It was a stock compression motor though. Even with port work and a cam , I didnt notice any difference between the stock one and the aftermarket.
For me, I would say unless you have a die hard setup motor, just plugging in a cdi box is a waste of money on a stock or mild modified motor.
i got a bbr one on my stock 02 xr70 and it seemed to make the motor wind out more. maybe not worth the 50 bucks though
I would think that the reason ( or what you noticed ) was lack of rev limiter. Whether it was truely making any more power wouldnt be noticed unless you threw it up on a dyno. While it may feel faster I would doubt it was really faster. Basically more noise and rpm always make things feel faster.
As I noticed the same thing on ours as you did. It would wind out more, but when it was raced at the drag strip, it made no et or mph difference between the stock cdi and our kitaco. Not saying that the BBR might not have made a difference though.
Which I think as you say, for the $50 I dont think it was really worth the difference in rpm limiter or lack of.
the timing curve on the stock box starts to kill the power at around 9500 rpm, no "limiter" on the stock cdi. the cam, valve springs, ect.. also limit the motor to about 9500 rpm.
you will get better throttle responce because the box' do slightly advance the timing, and maybe a few more rpm.
aka jack schitt
aka jack schitt
yep... unless you're running a 88 race head that's been worked over, big exhaust, big carb, Inner rotor kit with the clutch moved off the're not going to notice anything but a little better throttle responce.....
the bigger piston actaully woin't rev out as high as teh stock 50 piston in most cases ( more mass to move = slower)............. we have 2 88 race head bikes.. one has a big pipe and a stock rev box ( new style race head ).. it won't hit the stock limiter and won't rev any higher than the other one
the other one.. ( my personal bike ) has an old style race head on a stock pipe and a TB rev box... the only dfference is that the one with the TB box responds just a little faster on the initial throttle opening
both are running 20mm carbs jetted perfectly for their setups, adn both are running teh same cam ( stage 2 style.,.. a.k.a...the old race head cam)
liek fiveo said...even if you do get teh bike revved out that far, valve float start to make it run like ish anyway ... i got minebecause itwas 24 bucks adn it was shiny ( plus i didn't know anybetter at teh time )
rev boxes are only really good for highly modified motors. Tokyo Mods is one of the better boxes, but Trail Bikes rev is supposed to be pretty good and dosen't cost so much.
you'll notice more from a coil than a rev box. I think they are a gimmick if you ask me but I still buy em..haha. Tokyomods full setup is really the only one that probably actually does something.
Now on my end. my 117cc will not run on a stock CDI. I smoked a aftermarket one so I replaced it with the stock one and the bike felt like it lost half it's power and we did not race it the rest of the day. Now my bike likes to run at 13k so the stock will have it's limits. save your $40 and have the flywheel drop some LBS. stock trim a good bang for the buck.
theres no way the flywheel can even lose 1lb, and even if that doesnt help at all. you may feel the rpm climb and drop a bit faster, if u have a manual clutch.
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
