What are the differences between the E and S model?
Hi, sorry for the newbie question, but the link doesn't work in the FAQ section.
Anybody know of a working link as i can only find mindless dribble doin a normal web search.
dude, even I know that this subject has been discussed here a million times! do a search on this forum, not on the web...
It doesn't matter how many times it has been discussed if the search function is disabled....cut the guy some slack!
search results will be overwhelming anyway and therefore useless
In a nutshell...
E model has...
-Superior FCR carb.
-Hotter cam setup.
-Higher compression (Thinner base gasket)
-Lower gearing (14/47 versus 15/44)
-Softer rear spring (5.3 versus 5.5)
-No fan or t-stat.
-Knobby tires
-No rear sub-frame
-No passenger footpegs
-Less street junk
SK4 hit it on the head.
There is also a K version (Kicker) jult like the e without the magic button.
Not another one of them 'use the search button' forums are we...... :lame:
Degreez guy, i aint a 'forum' newbie and did try use the search on here but wasn't letting me search...even after the flood control filter!!
Seems a useful forum, i just know to ignore the forum whores with chips on their shoulders :p
Cheers :thumbsup:
to add to what sk4 has said,
the e model also has:
no steerring lock
no sidestand switch
lighter rate rear spring 5.3 kg. vs. 5.5 kg s model
head is milled to accept manual decompression
plastic gas tank(non-locking gas cap) frames are slightly different where tanks mount
no chain guard or tabs on swingarm
slightly different spokes (i'm getting petty here)
different front master cylinder(no switch & smaller)
different front brake line
slightly different rotors(front anyway)
manually operated fuel valve(gravity as opposed to vacuum)
that's all i can think of right now.
Cheers for all the replies :thumbsup:
Ok…… this response is getting so tiresome. Here’s a news bulletin for you guys that like to say… “this things been covered a million times why don’t you do a search?” A forum is for discussion, providing information and learning new things. If you don’t want to respond or read the thing skip it. No ones holding a gun to your head saying you have to respond to another 3X3 mod question. There’s only about 80 gazillion items discussed in TT on a daily basis. There’s going to be repetition…… DEAL WITH IT!!
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
