Husky te610e no electric start
Help have te610e 2000 kick/electric start engine in a sidecar enduro chassis,the engine has run fine but after a selector problem i now have other fault.Will kickstart first kick(kickstart mech bad design not very reliable so dont want to use to much)Electric start turns engine over produces spark but will not fire,compared to kick spark,electic spark is weaker.So far have checked /swapped battery(have had two batterys one starter one ignition)leads,plug,connectors,coil, stater motor,generator,ignition pickup,made no differnce.Carb is clean and runs fine when kicked.The only item i have no spare for is the cdi black box.The bike has no ignition switch just the stater switch.ANY IDEAS :thumbsup:
