05 450exc, 200hrs...am I crazy?
Been researching buying a street legal enduro (new ktm's, huskys) but also considering used street legal bikes. I have read all the BS about plates getting revoked, etc...
I am not really worried about getting a plate pulled as I have not read of an actual person having this happen (just "my friend knows a guy who got a letter")
My question to the experts is this?
I found a local 450exc 2005, but it has 200 hrs on it...$5600, I have always bought new bikes so I know I wont be STOKED with a 200 hr bike, but not ready to drop 8-9 grand on a new ktm/husky. SO is 200hrs a lot for a used bike?
When the registration on the plate is up, will I be able to renew?
You can't go by the hours alone - what is the bike's condition like overall? 200 hrs at 10 mph in the mud would use up most bikes. If it was ridden down country back roads at 40 mph by an old man, and meticulously maintained, it should be in great shape. You have to judge the condition and maintenance history. These are well built bikes but the valves and rings do wear out quickly, esp if the bike isn't well maintained. Overhaul is not a big deal, but it's always best to know exactly what you are buying to avoid nasty surprises.
I wouldn't shy away from a RFS with 200 hrs on it, but I sure would want some professional mechanical checks and info first.
As far as renewing the plate - that depends on where you live. Usually, once a bike is street titled it stays that way forever .... unless you let the tag expire. Then you may face an inspection, and things can get tricky with dual sported dirt bikes. Read up on the problems owners are facing in Kalifornia right now.
John Davies
Spokane WA
The engine will most likely need (at the least) intake valve replacement soon.
depends on how it's ridden i'd guess. i've had my fe550 for 6 months, and it has over 100 hard hours on it. the valves have been only the tiniest bit out of spec when adjusted. the bike looks pretty much new, even tho it's all hard off-road miles in nevada and idaho. only been crashed once tho, at about 10 mph.
i have a 2003 525 and not shure of the hours but its got a lot. the only thing I've had to do is adjust the valves acouple of time because it was running shitty but like that other guy said look at what kinde of shap of the bike is in
I paid $6500 for the same bike two years ago and it was brand new. You might take into account the cost of accessories, but $5600 for a bike with 200 hours of unknown maintenance would keep me looking a bit longer.
My '05 450 EXC only has about 20 hours on it and about $2600 worth of off-road and dual sport goodies on it. I'd still be lucky to sell it for $5600. It's better than new, WA plated and barely broken in.
Oh, yeah, it's not for sale.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
