'07 Shrouds on an '06
Anyone know if the new shrouds will fit an '06?
They were using them on Carmichal's bike and I think it was all stock except for the bar's and tires. Well maybe they had changed a few other things along the way.
But seriously I would bet the will fit as I doubt they changed much else after only 2 year models. Let me know as I might get some for our's now that you mentioned it.
I had read that as well...I was also trying to get a look at comparative bolt patterns...Can't find any real good pics comparing the two...
Anyone out there with an '07 that can post a good pic of the shrouds??
Thanks...Mitch
The 07 has 4 bolt holes to the 05-06 3 holes. If the other 3 are in the same place they may work. The extra bolt hole looks like it is at the top of the radiator.
Go on the to http://www.oneindustries.com/ you will have good pictures of both 05/06 and 07. Except for the 4th bolt the rest seems to fit their.
:thumbsup:
I actually spoke with One Industries today...they said that they had worked up the new graphics, with '07 shrouds on an '06. So, they do fit...however, the 4th bolt hole does not line up with the '06 radiators. Would need '07 radiators for that to work correctly. But...the '06's work fine with just the three...So, I may go with some '07's for the air flow...It is still in the 100's here in the desert...
Does anyone know which company has the Bomber (Mark Barnett) graphics? I thought it was One industries, but did not see them on their website.
In short, NO they won't. They are different. I have already checked and tried but they do not fit.
