Cheapest place to get Dunlop 208
Well it is time to get a new rear tire. Where is the cheapest place to get one. Thanks.
For two tires, I go here: [free shipping with two]
For one tire, I go here: [cheaper for one tire when you calculate shipping]
Although, I've heard a few complaints of it taking a few days longer from RA lately, not sure what is up with that. If you go with them, I'd call and make sure they have it in stock.
I am reading the sticky on sm junkies and I think I like Distanzias also
I would stay away from the 208's if I was you.
Yeah...there's so many great tires out there that there's no need to settle for a 208.
What if your stock front 208 is still good, should you run another rear 208 or something else...
I've never had any issues with running two different branded tires. If my rear 208 was toast and the front was still good, I'd still replace the rear 208 with something better.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
