how to tell difference between pipes
How do you tell the difference between Ti and SS, Yoshimura
By how much lighter your pocket is...I mean bike.
ti is dull grey with purpleing and their ss looks chromed.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
