Wanted: '84-85 XL/XR 250R Rocker Arms
Need a set for my '84 as mine are worn and I believe causing my top-end noise. Surfaces have grooves worn in them where they contact the cam. Anyone have some sitting around or a good source?
Have you tried Honda? They should be still available.
There are aftermarket sets on ebay, but I cant vouch for quality.
Lastly you can get the current set hard welded and run a hard weld cam, but this option is pricey.
I think you need to replace both cam and lifters if they are worn that much.
Definitely do, forgot to mention that.
Thanks for inputs...
Take a look at www.Webcamshafts.com. They sell hardwelded rockers and camshafts for the 84' XR/XL 250. You will get some nice power gains with a new camshaft and it might be cheaper than buying oem parts.
hey i got a 1984 honda xl250r do you know how much to adjust the rocker arms. I am having top end noise and I know it is the valves and the rocker arms. Or do you know were I can find this out?
