Edge 2 on an S ~
I am looking at the Edge 2 tail-light set-up for my 04 S as my fender mounted brake-light cheapo had a melt-down.
How much effort is needed to get a clean looking install ?
Thanks ~
Go with the standard edge with the metal bracket -- it's a direct bolt-on for the DRZ.
Yep. Looks sweet.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
