Parts for 41mm carb.
I was just wanting to know is the parts list the same for the 41mm FCRMX as the 39....Needle,bell housing etc...If not does anyone have part numbers..I maybe selling the 39 and need to know what to keep..Thanks
uses the same conversion parts.the jetting is way different though.
Ok thanks ed....Could you give ma a ball park on jetting...450 kit with cams..
here is mine..
450 w/ 1mm oversized valves, porting, full TI system, and 3x3. should get you close.
38 pilot
170 main
EMN needle
clip 3
1.5 turn fuel
good luck..
this is calculated from one i just did yesterday here.
178 main jet
200 main air jet
emp needle
clip 3
40 pilot jet
100 pilot air jet
2 turns fuel screw
put two 2.25" holes in your air box door.
maybe not.. :thumbsup:
Ok great thanks guys..DRS im going with the exact set up..Just waiting for everything to get here..Ill be selling the 39 soon ,so i keep everything but the needle..And get a emp..Thanks again guys.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
