Search function down? Pissed off?
yeah me too. But I realized that if I gave just a couple of bucks to the TT cause, the search would work all the time. :lame: Not really a plug for TT, but hey, with only a couple of bucks to be a TT Team member the search works all the time! Just give up that grande, non fat, skinny, extra shot, with sprinkles, twist, latte at Barstucks for one day. Its especially helpful at 1 am, when I'm nut deep in broken down bike parts and tools in the garage. :thumbsup:
Best money I ever spent. :thumbsup:
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
